Page 1 of 1
Chariots of Steel
Posted: Thu Apr 29, 2004 5:20 am
by david n. siegel
Not sure I'm done with this--may want to modify the repeat on the 4th part. Wanted a strong tune esp. for pipers who can hit low Gs with a firm reed.
Posted: Wed May 05, 2004 11:59 pm
by awpiper
Very nice tune.........However you may want to check your timing on the last bar of each part.....it does not measure 2/4......You have a 1/32 note on the double B, a 1/8th note with hold on a E, a 1/32 note tied to previous E, a G Grace note and a Low A 1/8th note.....the grand total would be 3/8 timing........But, if you change it to the 3/8 time signature you lose the "effect" of the tune in that bar.........Mark
Posted: Thu May 06, 2004 12:32 am
by Bloo
If you change it to this, it fits fine without loosing the effect and the timing is correct.
dbb Br_32 ^ts El_16 'e El_8 ^te gg LA_8
Cheers
B
Posted: Thu May 06, 2004 6:04 am
by david n. siegel
Thanks for the note and recommendations--I'm going over it again.
Always dangerous to proofread one's own stuff.
-david.
